Trunk And Door Not Closed In Cold Weather
vyhanh
Hi,
We have 0 (degree F) windchill here. My son's 91 LS400 has problem closing the trunk at first attempt. With several pulls of the trunk release tab, I eventually close it. Same with door (using the lock/unlock switch).
Any similar problem ? Any solution?
Thanks
VH
Oh, my god......32 degrees below freezing? Is that Siberia, Minnesota?
I assume that this problem did not exist before the cold snap?
Does a grease exist that won't freeze in that temperature? You need to find one and re-lube the latches, first cleaning off any old grease.
What is the actual (non-windchill) temperature?
Joe
