Struts On An Rx330
KBRX330
Has anyone done strut replacement on an RX330 yet? Any suggestions would be helpful. I am aproaching 145k on mine and two of the boots are torn but no leaks yet. Ride quality is still good but I suspect I'll replace them at 150-160k.
I replaced the front and rear struts and Strut mounts at 115K cost about 1300.00 local mechanic. You might just need the mounts that would be a cheaper fix. I suspect my problem was the mounts. Car was a little low and leaned on turns.
Hope that helps.
