dmolina2323 Posted May 27, 2008 Posted May 27, 2008 Does anyone know of a good company that removes dents and dings. I have a dent in between the front and back door to the panel above the window. Its about the size of a fist. I have an 08 IS 350 that is only 2 weeks old and some a-hole must have hit my car outside of the place i was eating at.
SW03ES Posted May 27, 2008 Posted May 27, 2008 Can you post a picture? Unfortunately it may not be repairable by paintless dent removal, it may have to be filled, primed, and painted. There are a few places on a car they can't get to with PDR, and if thats where I think it is...thats one of them...
dmolina2323 Posted May 27, 2008 Author Posted May 27, 2008 working on getting a pic up Im new to this site pls give me a few min
smooth1 Posted May 27, 2008 Posted May 27, 2008 they might be able to fix that for you at the paintless dent removal. Just have them look at it first, they will tell you if they can or not. Should only cost you less than a hundred bucks.
BaddBoi70 Posted May 27, 2008 Posted May 27, 2008 here it is what do you think? I just had 3 dents removed from my 06 IS 350 by a paintless dent repair shop and the guy did an AMAZING job! Not certain if this repair can be made, but if they can it will look brand new. Good luck :)
SW03ES Posted May 27, 2008 Posted May 27, 2008 Sorry to tell you, there's no way that can be repaired with PDR. They can't access the metal behind that because its a structural element of the car, and because of the side airbags behind it. Had it been in the actual roof panel it would have been possible. That'll have to be repaired with traditional bodywork. $1200-$1500 to do it right and match the paint...
