fordsvtmfl Posted May 25, 2008 Share Posted May 25, 2008 I have a 98 Gs300, and when I replaced some of the spark plugs I noticed a puddle of oil on/around the last 2 plugs. Any Idea what it is? A friend said head gasket leak, dad thought valve cover leak... Thanks Quote Link to comment Share on other sites More sharing options...
djspawn00 Posted May 25, 2008 Share Posted May 25, 2008 Valve Cover Gasket is the usual cause of this on many cars.. a head gasket leak would be noticable if you had overheating, coolant in your oil, loss of coolant, white smoke from you exhaust... its probably just the valve cover gasket which should not be too difficult to change... I'm thinking about changing mine in a few months when I get my timing belt done just so that I don't have to worry about it later. Quote Link to comment Share on other sites More sharing options...
fordsvtmfl Posted May 25, 2008 Author Share Posted May 25, 2008 Thanks, i will look into it. Quote Link to comment Share on other sites More sharing options...
Happy65 Posted May 26, 2008 Share Posted May 26, 2008 I have a 98 Gs300, and when I replaced some of the spark plugs I noticed a puddle of oil on/around the last 2 plugs.Any Idea what it is? A friend said head gasket leak, dad thought valve cover leak... Thanks Quote Link to comment Share on other sites More sharing options...
Happy65 Posted May 26, 2008 Share Posted May 26, 2008 When you changed the plugs did you remove the throttle body and if so did you have to replace the gasket? happy65 Quote Link to comment Share on other sites More sharing options...
