mburnickas Posted May 24, 2008 Share Posted May 24, 2008 Quick background: Moved down south and moving out. But 10 months and over 25K miles here is the outcome. No before since it was start at 5:35 am.. Drove up back up in Northeast (bought a house) and selling house in Spanish Country! Just did a quick 156 minutes external detail. I know the time since the sons blankets where in the steam dryer and it just finsihed when I put equ away! 1. Washed with Optimum No Rinse Wash & Shine; 2. Clayed (yellow) using Blue Mist Final wipe as Lube... 3. Applied Jeff Werkstatt Prime Acrylic, Makita 9227C using LC white pad @ 1,100 rpms. 4. Applied Jeff Werkstatt Acrylic Jett Trigger with LC Blue pad @ 1,2000 RPMS on Makita. 5. Used Chemical Guys Liquid Extreme Shine on lower plastic (under doors). 6. Used ONR on rims and tires (lazy) . 7. Tires where cleaned with Optimum Tire shine. 8. Rims sealed with PB EX-P. Left to dry entire time, then wipped. 1 out of 10 it looks like maybe a 6.. Quote Link to comment Share on other sites More sharing options...
mburnickas Posted May 24, 2008 Author Share Posted May 24, 2008 added better/bigger pix. It was before coffee. Quote Link to comment Share on other sites More sharing options...
smooth1 Posted May 24, 2008 Share Posted May 24, 2008 Ok, I'm confused here. So let me try to get this straight. 10 months ago you did a full detail? and now you just redetailed it? or what you just did you don't consider a detail, and here is what it looks like 10 months after a real detail? Quote Link to comment Share on other sites More sharing options...
mburnickas Posted May 24, 2008 Author Share Posted May 24, 2008 Ok, I'm confused here. So let me try to get this straight.10 months ago you did a full detail? and now you just redetailed it? or what you just did you don't consider a detail, and here is what it looks like 10 months after a real detail? Yes on the 10-months ago. And yes I just re-detailed it after 10-months. I said the detail, after 10-months does not look that great. Just showing how JW holds up. Quote Link to comment Share on other sites More sharing options...
smooth1 Posted May 24, 2008 Share Posted May 24, 2008 Oh, ok. :) Quote Link to comment Share on other sites More sharing options...
Lexusfreak Posted May 25, 2008 Share Posted May 25, 2008 Looks pretty good to me Mike! Quote Link to comment Share on other sites More sharing options...
