NABREU Posted May 18, 2008 Share Posted May 18, 2008 I have a 1996 LS 400 and my mechanic just repalce the main belt and water pump. Car runs great but the check engine light is on now. Code is P0340 - camshaft sensor. How can I debug. Also now the Trac Light constantly flashes and will not go off. Car runs great though. Any suggestion on how to debug these to issues? Quote Link to comment Share on other sites More sharing options...
smooth1 Posted May 18, 2008 Share Posted May 18, 2008 I moved this to the LS forum as it belongs here. Quote Link to comment Share on other sites More sharing options...
eatingupblacktop Posted May 18, 2008 Share Posted May 18, 2008 Welcome to the club. Try disconnecting the negative terminal of the battery for 10 minutes, then reconnect. If there's nothing seriuosly wrong, the computer should reset itself. Quote Link to comment Share on other sites More sharing options...
tsarang Posted January 29, 2010 Share Posted January 29, 2010 Guys, I am having the exact same problems. Please let me know if you were able to resolve this?. If yes then what was the resolution. any detailed procedure carried out will help. Quote Link to comment Share on other sites More sharing options...
steve2006 Posted January 29, 2010 Share Posted January 29, 2010 So have you bought the car off the guy who had the same problem in May 2008 and never got it fixed or have you just had the belt and water pump replaced by the same mechanic and now have the same problem? Quote Link to comment Share on other sites More sharing options...
