I have spent months trolling the CL forums and have been tired of the way they handle members there.
I have decided to start my 97+ conversion for this summer.
Here is what I want to accomplish this summer:
97+ front bumper cover
97+ bumper grille
98-04 Dodge Intrepid fog lights with modification to fit 97+ SC bumper cover.
Front clip respray
Fix the AC: When I got the car, the compressor would "cycle". I got a 95 R134A compressor and it does not work. Still throws code 23 of low pressure or whatever. Do you think just getting a new compressor would fix this?
I also want to fix the passenger side door so it opens from the inside.
Also, I notice now that along with the Ebay headlight assemblies, there are now Ebay high beam assembly listings with projector headlights. Anyone have the low or high beams from ebay yet?
I haven't yet.
I'm waiting to afford a reman compressor from this reputable guy on Ebay. He sells reman SC300 Denso OEM compressors for about $220 USD shipped to my door. Friends have used him for a few other cars and rate his service well.
As soon as I change the compressor, should I THEN evac and recharge?
Any thoughts on my 97+ update?
Im not sure the compressor is your problem.
The compressor may not be running to protect itself from the low pressure.
A common problem is a hole that gets worn in the AC lines that run near the bottom of the radiator.
You may find a leak there.
Tom
The compressor was cycling, which indicates a bad compressor. It can't hold anything coming into it. This was checked at a repair shop by an AC professional.
And I have decided on the Ebay Headlights. W00T
Oh and JZZ30, the 97 skirts and rear aren't a priority. The will most likely come not next summer but the summer after. Next summer the 72 Celica gets some major rust work.
