( Help Asap) - 20" Wheels Fittment
Al.
Hi All,
I own a 98 LS400 and I am considering a wheel upgrade to 20" wheels all around as follows:
Wheel Size: 20x8.5
Bolt Pattern: 5x114.3
Wheel Offset: +42
Tire Size (F & R): 245-35-20
My question is do I need to roll the LIP of the fender to make this type of set up fit. Also please note that I recently upgraded my shocks to Bilstein shocks in which I do not know if it will have an adverse effect on this application or not.
Thanks for your feed back
Al.
You need to make sure the wheels will fit over your brakes the offset does tno tell you.
Thanks SKP. I am aware of this...I just need to know if the 20" will go on fine without any rubbing to fender.
