Romiex69x Posted May 10, 2008 Share Posted May 10, 2008 I replaced the fuel pump, lot of things didn't fit the way they were suppose to, the conector that goes into the fuel pump didn't match up so I had to cut it off and put some wire crimps on it, the rubber piece at the bottom didn't line up, so I just zip tied the pump to the metal thing which holds it in place, but because of that the rubber hose isn't on very good because it wasn't lining up, but it's on. well I submerged it. And tried to start the car, but nothing, didn't even come close, didn't sound like a single drop went to the engine, just starter spinning and spinning and nothing happening, I kept going, pressing the gas, or not. And absolutely nothing, how do I know if the pump is working or if the problem is somewhere else? Any sugestions, I'm getting really frustrated. Quote Link to comment Share on other sites More sharing options...
EPIX INC Posted May 11, 2008 Share Posted May 11, 2008 take a test light and see if u even get power to the pump when cranking or key on. if not, the problem could lie with the fuel pump ecu located is panel directly behind drivers seat under the window. just bypass ity by attaching the two thicker gauge wires together from the harness going into the fuel pump ecu/ Quote Link to comment Share on other sites More sharing options...
Romiex69x Posted May 11, 2008 Author Share Posted May 11, 2008 take a test light and see if u even get power to the pump when cranking or key on. if not, the problem could lie with the fuel pump ecu located is panel directly behind drivers seat under the window. just bypass ity by attaching the two thicker gauge wires together from the harness going into the fuel pump ecu/ All right, thanx, I'll give it a try. I'm pretty ready just to part the car out. Quote Link to comment Share on other sites More sharing options...
xaine Posted May 14, 2008 Share Posted May 14, 2008 take a test light and see if u even get power to the pump when cranking or key on. if not, the problem could lie with the fuel pump ecu located is panel directly behind drivers seat under the window. just bypass ity by attaching the two thicker gauge wires together from the harness going into the fuel pump ecu/ All right, thanx, I'll give it a try. I'm pretty ready just to part the car out. well if you do that i need some parts, but like the other said test the power if your getting power right after you turn the key on, the the pump should work if everything is hooked up right if your not getting power then the problem is some where else perhaps the security system, igniton switch, ecu then you need to make sure the pump is pumping gas and if both those are good then make sure the fuel is making it to the fuel rail Quote Link to comment Share on other sites More sharing options...
