fisher972002 Posted April 23, 2008 Share Posted April 23, 2008 All, Quick ?] 1991 LS400 I replaced my rear brakes with lexus factory pads.. Turned the disc rotors.. I am getting a very slight squeak, when I apply the brakes very lightly.. Do you guys suggest applying a little silicone on back of the brake pad metal, or on a anti-squeal metal shim.. Or do both, or just the pad?? What do you guys do.. I've been driving for a few months, I thought it would quit squeaking after a little while, the way the brakes fit in the caliper it seems like you would only put a little quieter/Silicon on the back of hte pad only and let the antisqueal shims move.. ALso I bought new antiq squeal springs when I replaced the pads, but re-used the metal shims. Thanks Quote Link to comment Share on other sites More sharing options...
jcrome04 Posted April 23, 2008 Share Posted April 23, 2008 You should usually always grease up new pads so they don't squeal or move around. Did you do it at all? Quote Link to comment Share on other sites More sharing options...
TexasLexus94 Posted April 24, 2008 Share Posted April 24, 2008 Call me Mr. Stupid, but I always install new rotors when installing new pads. Too many times, I have installed new pads, even oems, on recently ground rotors. Still have squeaks, etc. With new rotors and pads, all is peachy. $120 for the fronts, $100 for the rears. Each. Raybestos for me. Maybe they won't last as long, but they sure are quiet and smooth. Oh, always install ceramic pads, too.... Quote Link to comment Share on other sites More sharing options...
fisher972002 Posted April 24, 2008 Author Share Posted April 24, 2008 jcrom, I put a some disc brake caliper grease on the prongs of the pad, you know hte ends that are square that slide on the spring clips, put a little there, but you are saying on the back of the pad also then? Quote Link to comment Share on other sites More sharing options...
