Samsam865 Posted April 22, 2008 Share Posted April 22, 2008 Hi, my RX 350 has the dim lights on all the time, even if I turn off the lights. I'm pretty sure they are all like that, but is there anyway I can turn the lights off completely? Thanks alot. Quote Link to comment Share on other sites More sharing options...
ilovelexus2007 Posted April 22, 2008 Share Posted April 22, 2008 Hi, my RX 350 has the dim lights on all the time, even if I turn off the lights. I'm pretty sure they are all like that, but is there anyway I can turn the lights off completely? Thanks alot. I don't think you can, even when you put it on auto. There is not an "off" button. But what's wrong with having your headlights on in daylight? Quote Link to comment Share on other sites More sharing options...
wwest Posted April 23, 2008 Share Posted April 23, 2008 Hi, my RX 350 has the dim lights on all the time, even if I turn off the lights. I'm pretty sure they are all like that, but is there anyway I can turn the lights off completely? Thanks alot. If you look under the battery mounting/support plate you will see a fairly high wattage resistor that is used to "dim" the high beam headlamps when they are being used as DRLs. Unplug that resistor and your DRLs will go OUT. Quote Link to comment Share on other sites More sharing options...
rx350guy Posted April 23, 2008 Share Posted April 23, 2008 They are designed to be on all the time for safety, and yes, they're all like that.. Quote Link to comment Share on other sites More sharing options...
