Rx 350 Headlights
Hi, my RX 350 has the dim lights on all the time, even if I turn off the lights. I'm pretty sure they are all like that, but is there anyway I can turn the lights off completely? Thanks alot.
I don't think you can, even when you put it on auto. There is not an "off" button. But what's wrong with having your headlights on in daylight?
If you look under the battery mounting/support plate you will see a fairly high wattage resistor that is used to "dim" the high beam headlamps when they are being used as DRLs. Unplug that resistor and your DRLs will go OUT.
Loading...
 Share
