93lexES300 Posted April 18, 2008 Share Posted April 18, 2008 Just got a 1991 LS400 and I have a few questions about it's quirks. First question is the TRAC light, and yes, I have searched the forum. My question is the "motor" for the traction control has been replaced about a year ago by the previous owner, but the TRAC light still intermittantly comes on. Where are the Traction control sensors located at the back wheels? I'm about to do a rear brake job and flush the brake fluid as this has not been done is many years, and perhaps this will solve the problem, but I also wanted to get an idea of where the sensors are in case I need to replace those. Second question is regarding power steering. I've searched this forum for the filter that seems to clog up for the power steering, but I can't seem to find a picture of exactly where this filter is. Thanks Much.... Quote Link to comment Share on other sites More sharing options...
fiveofakind Posted April 18, 2008 Share Posted April 18, 2008 Drain the fluid out of the P/S Pump with a turkey baster & you will see the screen at the bottom of the pump...remove with care as this screen is very brittle & clean.... Quote Link to comment Share on other sites More sharing options...
93lexES300 Posted April 18, 2008 Author Share Posted April 18, 2008 Drain the fluid out of the P/S Pump with a turkey baster & you will see the screen at the bottom of the pump...remove with care as this screen is very brittle & clean.... Is it necessary to remove the pump to do this? Or is this from the top? Which hose to disconnect? Thanks Quote Link to comment Share on other sites More sharing options...
IansLexus Posted April 18, 2008 Share Posted April 18, 2008 Drain the fluid out of the P/S Pump with a turkey baster & you will see the screen at the bottom of the pump...remove with care as this screen is very brittle & clean.... Is it necessary to remove the pump to do this? Or is this from the top? Which hose to disconnect? Thanks There you go man!! Best wesbite for LS400s ever! http://www.lexls.com/tutorials/steering/psflush.html Quote Link to comment Share on other sites More sharing options...
93lexES300 Posted April 18, 2008 Author Share Posted April 18, 2008 Drain the fluid out of the P/S Pump with a turkey baster & you will see the screen at the bottom of the pump...remove with care as this screen is very brittle & clean.... Is it necessary to remove the pump to do this? Or is this from the top? Which hose to disconnect? Thanks There you go man!! Best wesbite for LS400s ever! http://www.lexls.com/tutorials/steering/psflush.html That's what I was looking for :) Your help is greatly appreciated !!! Quote Link to comment Share on other sites More sharing options...
