Initially I thought my Fan Bracket bearing was making noise. So I did some reading here and try to remove it, but while removing it, I also found out the Tensioner bearing was bad then replaced them. After replaced them, noise still there then I replaced the belt idler bearing and the serpentine belt. Now, my car is running smooth at start up. The idle always set 1100rpm rather than 1500-1700rpm.
So, for those of you have problem with high idle problem. This could be solved if you replaced these items. Happy ending.
