'92 Cv Boot
I need to replace the front left CV boot on my '92 ES. Has anyone use the CV kit with the split boot that you don''t have to pull off the CV? If so, how did it work out? Where can I get one on-line?
Thanks
Don
I wouldn't recommend the split boot since dirt/rocks/debris has already entered the torn cv boot. If you simply cover the torn boot without cleaning out the old grease and packing fresh, clean grease, the contaminants will wear your cv joint, and you will hear clicking pretty soon and then have to replace the entire cv joint.
YOu don't cover the old boot. You remove the cracked boot clean the joint and repack before replacing. the new split boot just eliminates the need to remove the axle. I have used the split boots with success in the past.
I went with the split boot on my 92 about 3 years ago and havent had any problem. I don't remember if i purchased from advanced auto, or autozone, but the odd thing was that they didn't have a listing for Lexus, but had it for the Camry. It was a direct match, and worked perfectly. It came with new grease as well...
Hope this helps...
Ron
