Texas Aggie Posted March 28, 2008 Share Posted March 28, 2008 I am going to add R134 Freon to my 96 LS400...Any helpful hints/shortcuts: How hard is it to get to the supply line, where is the supply line, etc... Thanks Quote Link to comment Share on other sites More sharing options...
jcrome04 Posted March 28, 2008 Share Posted March 28, 2008 Its very simple and straight forward. Just be careful not to overfill it. Or add it to the wrong port. Quote Link to comment Share on other sites More sharing options...
gabep Posted March 28, 2008 Share Posted March 28, 2008 If you are not familiar with A/C systems I suggest you have it done in a shop. You can trash the system if you do it incorrectly. Quote Link to comment Share on other sites More sharing options...
TA in KC Posted March 28, 2008 Share Posted March 28, 2008 If you are not familiar with A/C systems I suggest you have it done in a shop. You can trash the system if you do it incorrectly. Once you have learned how to do it, recharging the system is fairly easy. It is worth learning how, because having it done professionally is very expensive. You can get the exact same results doing it yourself and you save a very substantial amount of money. The low side service port is where you recharge the system. It has a black dust cap covering it. There is a smaller one that looks similar with a red cap, the high side service port. You should never attempt to charge the system from this port, but it is nearly impossible to do so because the connectors will not physically fit. Take a look at some of these instructional videos. They cover most everything you will need to know about recharging the system, and are made for do-it-yourselfers. http://id-usa.com/how_to_videos.asp Quote Link to comment Share on other sites More sharing options...
