I bought my 200k lexus sc300 about a month ago and held off on changing the oil since the owner just replaced all the filters in the system herself and had jiffylube replace her oil a few hundred miles before i got on it. Now after 2k miles.. yeah i put it on quick! newly purchased cars are always fun to cruise around in.. for hours, i'm now changing my own oil/oil filter.
I'm using 5W-30 Castro GTX High Mileage oil and a mobil1 filter, i jacked up the front about a foot, drained it, jacked up the back about a foot, drained it some more, let it drain flat on the ground till it was a drip every 10 seconds, put the plug back in and then proceeded to fill it up with 5 quarts. i stopped at exactly 5 quarts, my SC300 manual on page 170 it says:
drain and refill, with filter, 5.1qt, without filter, 4.8qt.
I replaced the filter, but at exactly 5.0qt my dip-stick says ive overfilled it, it's a pretty marginal amount, about 1/8" above the full mark, is this worth getting down there, opening it up and draining a bit and quickly plugging it back up (causing a mess) just to get it to the full mark or is a little overfill not worrysome?
I'm sort of too afraid to drive it at the moment until i know more about slightly overfilling.
Just curious, thanks.
-Joe
did you start the engine to let the oil get in to the filter and this and that? the level will drop a bit.
Slightly over or underfilling your car will do it no harm. They are designed to operate inside a parameter of oil. One court low, or one court high, generally shouldnt be any probs on a good car.
I don't see a small amount of overfill as a problem. I have been told that too much oil can damage the catalytic converter. Common sense should prevail.
