Graphite Lube
93ls400walt
My key hangs now and then. ( even when the wheels are straight ) when I try to turn the key to start her up. Wiggling the wheel does not help. Will the graphite affect sensors in the ing. switch ?
93ls400
Walt, in my experience the answer is no. Lubrication is called for on worn parts. Don't share this with your wife. ;) In all seriousness, graphite will do the job.
Just make sure that id the graphite doesn't work, you don't go spraying fluid in after, it gets VERY messy. I recommend graphite on the key only first, just in case that does the trick.
