kimo Posted February 27, 2008 Share Posted February 27, 2008 hello, we have a 2001 rx300, 85000 miles. I had the vsc/cel lights come on yesterday. checked the computer and was given a code. p0440. evap, I already checked the fuel cap, have pressure when you unscrew it. so I assume that the cap is Ok ?? or possibly a leak in a vacum line?? any more thoughts would be helpful. I have read some of the other threads about this issue and other than the obvius, like a loose line. Im not seeing anything like that on my car. maybe I should buy a new fuel cap and go from there. thank you Quote Link to comment Share on other sites More sharing options...
wwest Posted February 27, 2008 Share Posted February 27, 2008 hello, we have a 2001 rx300, 85000 miles. I had the vsc/cel lights come on yesterday. checked the computer and was given a code. p0440. evap, I already checked the fuel cap, have pressure when you unscrew it. so I assume that the cap is Ok ?? or possibly a leak in a vacum line?? any more thoughts would be helpful. I have read some of the other threads about this issue and other than the obvius, like a loose line. Im not seeing anything like that on my car. maybe I should buy a new fuel cap and go from there. thank you If the fuel cap is removed and no fuel is added to the tank, or the cap leaks due to being poorly seated temporarily, you will get this code. If it was a loss of vacuum in the fuel system the CEL will clear within a few drive cycles. Quote Link to comment Share on other sites More sharing options...
kimo Posted February 28, 2008 Author Share Posted February 28, 2008 hello, we have a 2001 rx300, 85000 miles. I had the vsc/cel lights come on yesterday. checked the computer and was given a code. p0440. evap, I already checked the fuel cap, have pressure when you unscrew it. so I assume that the cap is Ok ?? or possibly a leak in a vacum line?? any more thoughts would be helpful. I have read some of the other threads about this issue and other than the obvius, like a loose line. Im not seeing anything like that on my car. maybe I should buy a new fuel cap and go from there. thank you If the fuel cap is removed and no fuel is added to the tank, or the cap leaks due to being poorly seated temporarily, you will get this code. If it was a loss of vacuum in the fuel system the CEL will clear within a few drive cycles. had a friend check system and got a different code today 1150 af sensor im told, is that the one in front of the engine? thanks Quote Link to comment Share on other sites More sharing options...
ZAPP Posted March 2, 2008 Share Posted March 2, 2008 WHY would fuel cap have any bearing on VSC???? unrelated... i think. Quote Link to comment Share on other sites More sharing options...
