tdandkd Posted February 25, 2008 Share Posted February 25, 2008 I need to get to the blower motor for the heating and A/C and understand that it is behing the glove compartment. What is the easiest way to remove the glove compartment? Also, do you only need to disconnect the negative battery cable and shield it to disable the airbag system while working around the dash? Quote Link to comment Share on other sites More sharing options...
wwest Posted February 25, 2008 Share Posted February 25, 2008 I need to get to the blower motor for the heating and A/C and understand that it is behing the glove compartment. What is the easiest way to remove the glove compartment? Also, do you only need to disconnect the negative battery cable and shield it to disable the airbag system while working around the dash? Start at the bottom, where a tall passenger's toes might be. Quote Link to comment Share on other sites More sharing options...
