TomTA Posted February 14, 2008 Share Posted February 14, 2008 The other day we finally had some clear weather and I opened up the trunk, sun roof, and door windows. To my surprise the right door window did not move. It worked freely without a hint of problems the last time I opened the window. Checking the fuses it appears that the windows are both on the same fuse, which rules that out if true. Is there anything simple that I should look at before I tear the whole door and window assembly apart to figure it out? Tom :( Quote Link to comment Share on other sites More sharing options...
eds92sc Posted February 14, 2008 Share Posted February 14, 2008 The other day we finally had some clear weather and I opened up the trunk, sun roof, and door windows. To my surprise the right door window did not move. It worked freely without a hint of problems the last time I opened the window.Checking the fuses it appears that the windows are both on the same fuse, which rules that out if true. Is there anything simple that I should look at before I tear the whole door and window assembly apart to figure it out? Tom :( If you hear the motor going, then I suspect you have a bad window regulator. If you hear nothing, perhaps it's the motor. I bought a new regulator online from a Lexus dealer for about $115. Motor costs a lot more. Quote Link to comment Share on other sites More sharing options...
grnsc40095 Posted February 14, 2008 Share Posted February 14, 2008 TomTA, This may be your solution to your problem? http://www.clublexus.com/forums/showthread...?threadid=95720 Quote Link to comment Share on other sites More sharing options...
sc300max Posted February 15, 2008 Share Posted February 15, 2008 Yea if you hear the motor going it could be just the regulator. Also see if you can manually push the window down while holding the switch down. Could just be stuck because of the weather and worn lubrication. Quote Link to comment Share on other sites More sharing options...
TomTA Posted February 16, 2008 Author Share Posted February 16, 2008 TomTA, This may be your solution to your problem?http://www.clublexus.com/forums/showthread...?threadid=95720 Thanx for the questions and the great link. Unfortunately I don't hear the motor running, so I suspect an electrical connection problem, or the motor itself. The thread about rebuilding the window regulator is great and I have saved it for future use. Tom Quote Link to comment Share on other sites More sharing options...
aliga Posted February 16, 2008 Share Posted February 16, 2008 if you need the motor or any parts to fix it, i have it. you can reach me at gazi_ali@hotmail.com Quote Link to comment Share on other sites More sharing options...
