Is 300 - Timing Belt Change
antidot
hi !
i just crossed 90,000 miles mark, and dealership dude told me timing belt change is "recommended" at this time.
Is that true ? :huh:
How much time/miles do i have till timing belt really might fall apart ?
Is it another good 10,000 miles or should i replace it immediately ?
pls let me know what you think..
i kinda don't want to spend $900 if i don't really have to..
thank you
hi !
thank you
Depends how you drive the car, It is recommended @90k. If you drive normally you may have up to 30k left. I have the same motor in my GS and I had mine changed @around 110k and the belt looked great. Have the waterpump changed @ the same time, It will save you $ down the road.
thank you !
dcfish, an how exactly do you drive your car that your timing belt lasts so long ?
(if you don't mind me asking :rolleyes: )
hi !
thank you
