antidot Posted February 6, 2008 Share Posted February 6, 2008 hi ! i just crossed 90,000 miles mark, and dealership dude told me timing belt change is "recommended" at this time. Is that true ? How much time/miles do i have till timing belt really might fall apart ? Is it another good 10,000 miles or should i replace it immediately ? pls let me know what you think.. i kinda don't want to spend $900 if i don't really have to.. thank you Quote Link to comment Share on other sites More sharing options...
dcfish Posted February 6, 2008 Share Posted February 6, 2008 hi !i just crossed 90,000 miles mark, and dealership dude told me timing belt change is "recommended" at this time. Is that true ? How much time/miles do i have till timing belt really might fall apart ? Is it another good 10,000 miles or should i replace it immediately ? pls let me know what you think.. i kinda don't want to spend $900 if i don't really have to.. thank you Depends how you drive the car, It is recommended @90k. If you drive normally you may have up to 30k left. I have the same motor in my GS and I had mine changed @around 110k and the belt looked great. Have the waterpump changed @ the same time, It will save you $ down the road. Quote Link to comment Share on other sites More sharing options...
antidot Posted February 6, 2008 Author Share Posted February 6, 2008 thank you ! dcfish, an how exactly do you drive your car that your timing belt lasts so long ? (if you don't mind me asking ) hi !i just crossed 90,000 miles mark, and dealership dude told me timing belt change is "recommended" at this time. Is that true ? How much time/miles do i have till timing belt really might fall apart ? Is it another good 10,000 miles or should i replace it immediately ? pls let me know what you think.. i kinda don't want to spend $900 if i don't really have to.. thank you Depends how you drive the car, It is recommended @90k. If you drive normally you may have up to 30k left. I have the same motor in my GS and I had mine changed @around 110k and the belt looked great. Have the waterpump changed @ the same time, It will save you $ down the road. Quote Link to comment Share on other sites More sharing options...
bartkat Posted February 6, 2008 Share Posted February 6, 2008 dcfish drives like a granny. :D Quote Link to comment Share on other sites More sharing options...
