t.go Posted February 5, 2008 Report Share Posted February 5, 2008 I have a 1999 ES300 - 107k miles, which was miss firing intermitantly. The codes I pulled were 1354 (VVT bank 1), (300,302,304,306 misfires bank 2). I replaced the OCV on bank 1 to address code 1354. The condition and codes came back in addition to code 1351. Alldata said 1351 was caused by a skipped timing belt or a bad ECM. The timing belt was replaced 6 months ago and is still in correct timing. I purchased a used ECM. The battery was disconected for a few days while the ECM was being shipped. Now the car turns over but will not start, I have tried 2 keys. The security light on the dash is flashing and the remote fobs are operating normally. Did I loose the progaming in the security key? If yes, is this from changing the ecm or having the battery disconnected for an extended period. Finally, Is there a way to correct this short of towing it to the dealer? Quote Link to comment Share on other sites More sharing options...
t.go Posted February 6, 2008 Author Report Share Posted February 6, 2008 I thought would pass on what I have learned in regards to replacing ecm's. A replacement ecm would have to be flashed to be put in relearn mode. You would then insert the key for 5 seconds (do not turn on) and remove. Repeat for extra keys. A local automotive locksmith will flash the ecm for $150 (With the ecm out of the car ). I'm not sure what Lexus charges. An alternate to changing out the ecm is having the current ecm repaired. There is a company in Houston (www.ecmtogo.com) that will repair the computer for $225. This eliminates the key hassle and is much cheaper than the $800 Lexus wants for a reman'd ecm or $1300 for a new one. I would still be interested in feedback from others on this subject. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted February 6, 2008 Report Share Posted February 6, 2008 If it is an alarm lock out , their is a procedure to relearn the keys by using the pedals and turning the ignition. I did it on my 98 LS400 and it programmed the key i still use the key today . Search the site for key reprogramming , one is for the door locks the other is for the ignition lock out. Quote Link to comment Share on other sites More sharing options...
