lahermano Posted January 22, 2008 Posted January 22, 2008 Hi guys, I brought my Lexus (110k miles, out of 100k warranty) to the Lexus dealer, as i found a burnt smell from the car. They said there is a slight oil pan gasket leak and recommended changing that. My questions are : 1. They quoted $400 for oil pan gasket replacement job 2. I also have to get the timing belt replaced. Lexus quoted for $900. Are these quotes fair or a rip ? 3. If i get these both done, is there an overlap of labor that could be saved ? or these are two different jobs that need its own labor time. 4. does these jobs need a Lexus skilled labor ? or they can be done with any other car mechanics ? Any recommendations ? how i can optimize the spending amount ? Regards Newbie
lenore Posted January 22, 2008 Posted January 22, 2008 Some of us get the work done at a toyota dealership (timing belt) for half the price. As for the oil pan I would assume they can do that too. An independent garage should be able to do the job as well. But I would only go to a trusted one or one that does Toyotas.
