I've got a nice 95 ES, but some bulbs are out on the dash. Getting to them is easy enough but I can't seem to find those little bulbs anywhere but the dealership. Does anyone know if you can get them somewhere else cheaper?
I also tried looking for them but I had no luck also. I think that you can get led bulbs that fit the dash but not too sure where to get them. If you find out anything please post it.
You can make leds fit but then they are going to leave black or dark spots .As an led has a very narrow field of light it produces.
So pretty much only lexus has the bulbs.
Thanks for the direction on the bulbs. I'm going to keep looking because Lexus has to get them from somewhere. Unless it's a bulb made only for Lexus and only sold to Lexus, we should be able to find them. I hope :)
It is not just a case of just the bulb as they are inserted into a base that is one peice with the bulb to make it a lexus application only.
Are you saying that the bulb doesn't just plug into the bayonet base and then into the board and that it's all one peice?
