Indio Posted January 4, 2008 Share Posted January 4, 2008 I guess it shows how few and minor the problems are with my '02 430, but the only problem I have yet to figure out is that the outside temperature reading on the console is always about 3 degrees warmer than the actual outside temperature. Call it being picky, but does anyone know if there is a way to adjust the calibration so that it reads correctly? Quote Link to comment Share on other sites More sharing options...
mburnickas Posted January 4, 2008 Share Posted January 4, 2008 I guess it shows how few and minor the problems are with my '02 430, but the only problem I have yet to figure out is that the outside temperature reading on the console is always about 3 degrees warmer than the actual outside temperature.Call it being picky, but does anyone know if there is a way to adjust the calibration so that it reads correctly? Here is one. how do you it is wrong? I go by weather.com (says one thing). I go by banks etc and all are diff. Quote Link to comment Share on other sites More sharing options...
Indio Posted January 4, 2008 Author Share Posted January 4, 2008 I guess it shows how few and minor the problems are with my '02 430, but the only problem I have yet to figure out is that the outside temperature reading on the console is always about 3 degrees warmer than the actual outside temperature.Call it being picky, but does anyone know if there is a way to adjust the calibration so that it reads correctly? Here is one. how do you it is wrong? I go by weather.com (says one thing). I go by banks etc and all are diff. It never agreed with the radio, so I brought a calibrated thermometer home from work and placed it in the garage next to the car. Next morning they differed by 3 degrees... Quote Link to comment Share on other sites More sharing options...
raymsixsix Posted January 4, 2008 Share Posted January 4, 2008 Hey Indio, do you only notice it inaccurate when you first start up the car? Because the reading won't be accurate until you've driven the car for about five mins. I've found them to be most accurate if the car is moving and not sitting in traffic, because the heat from the engine can sometimes affect the readout. Quote Link to comment Share on other sites More sharing options...
Indio Posted January 14, 2008 Author Share Posted January 14, 2008 Hey Indio, do you only notice it inaccurate when you first start up the car? Because the reading won't be accurate until you've driven the car for about five mins. I've found them to be most accurate if the car is moving and not sitting in traffic, because the heat from the engine can sometimes affect the readout. You may have a point, I usually notice when I first start the car, and it is always too high. I know if I'm in a traffic jam it will read even higher as you noted, but it still would be nice if you could set it. I'll keep searching for a way, if I find it I'll post it here since now everyone is probably checking the accuracy of theirs. :whistles: Quote Link to comment Share on other sites More sharing options...
intdiamond Posted March 9, 2008 Share Posted March 9, 2008 Hey Indio, do you only notice it inaccurate when you first start up the car? Because the reading won't be accurate until you've driven the car for about five mins. I've found them to be most accurate if the car is moving and not sitting in traffic, because the heat from the engine can sometimes affect the readout. You may have a point, I usually notice when I first start the car, and it is always too high. I know if I'm in a traffic jam it will read even higher as you noted, but it still would be nice if you could set it. I'll keep searching for a way, if I find it I'll post it here since now everyone is probably checking the accuracy of theirs. :whistles: Hi- Just to chime in, my '02 SC is also about 3 degrees high and my wife's '06 LX is always about 5 degrees high, even after we've driven the car for a while and it's warmed up.... then again, are any thermometers ever accurate? Quote Link to comment Share on other sites More sharing options...
