Bulb Size Question
SW03ES
Hey guys,
What size bulb is that little running light up at the top of the 02-06 ES' headlamp? Is it a 194 wedge bulb?
One of mine is out...
Pretty sure its a 192. Lexus is real funny about those so make sure you put the right one in. Wrong bulb numbers will trip indicator light or burn sockets.
silverstar gives it as 2825 which is the same size as T10, T-10, 194, 168, 158, 12256, 12961, 2821, 2825, W5W so it should be good. Have you thought about switching over to LED's? They make a "warm-white" color LED that emits the same (about...) color as a bulb just uses half the e- and will last forever.
The "bulb-out" indicator doesn't apply to parking lights/sidemarkers so putting in LED's won't cause a problem.
