Ultraguy Posted December 9, 2007 Share Posted December 9, 2007 Recently purchased an 04 Ultra and have some questions. Is the sport setting on this car the same as the sport suspension option on the sport version....I know the ultra has air supension. Is the sport setting just a firm up the shock? Is the sport option on the regular car just a sport shock or is it springs and sway bars? Is the high setting on the suspension just for the rear when the car is laden? Or does it adjust all 4 corners? How can I check to make sure the air suspension is functioning properly and is not leaking? I am running the stock 17 inch wheels with 225/55/17 with Dunlops. Have orderd 19 inch Michelins 245/40 with 19 by 8.5 inch Modas. Wouls I be better to go with the 18 inch by 7.5 inch stock Lexus wheels? Does anybody have an opinion about this setup? Sway bar options? Thanks! Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted December 9, 2007 Share Posted December 9, 2007 This article has a comparison between the spring based Sport Suspension and the sport setting on the Ultra air suspension system: http://www.automotive.com/2004/12/lexus/ls...iews/index.html Regarding the information in the article about using the high setting for driving in deep snow, I would hope you would not need that very often in Forida! Maybe it would help when it rains really hard, LOL. Quote Link to comment Share on other sites More sharing options...
jainla Posted December 9, 2007 Share Posted December 9, 2007 The sport suspension is a different set of sway bars and bushings (and also I think shocks); also it came with the larger wheels as standard. I've never driven the sport suspension car (they seem to be quite rare) but from the review mentioned by Jim and others I've read it was quite a good blend of ride/handling and firmer than the air suspension set on sport. The High setting seems to raise the overall ride height (as far as I can tell). The ride also gets a little harder when the setting is on High. The biggest indicator of leaking air lines or springs is when the car has sat overnight; if it looks like a low rider then you probably have a leak somewhere; also the shocks inside the air struts can leak; most dealers or service centers will see that. Someone in this forum mentioned something about using the rear sway bar from the sport suspension option as a replacement for the standard sway bar on the ultra. Welcome to the club! Recently purchased an 04 Ultra and have some questions. Is the sport setting on this car the same as the sport suspension option on the sport version....I know the ultra has air supension. Is the sport setting just a firm up the shock? Is the sport option on the regular car just a sport shock or is it springs and sway bars? Is the high setting on the suspension just for the rear when the car is laden? Or does it adjust all 4 corners? How can I check to make sure the air suspension is functioning properly and is not leaking? I am running the stock 17 inch wheels with 225/55/17 with Dunlops. Have orderd 19 inch Michelins 245/40 with 19 by 8.5 inch Modas. Wouls I be better to go with the 18 inch by 7.5 inch stock Lexus wheels? Does anybody have an opinion about this setup? Sway bar options? Thanks! Quote Link to comment Share on other sites More sharing options...
Ultraguy Posted December 9, 2007 Author Share Posted December 9, 2007 This article has a comparison between the spring based Sport Suspension and the sport setting on the Ultra air suspension system: http://www.automotive.com/2004/12/lexus/ls...iews/index.htmlRegarding the information in the article about using the high setting for driving in deep snow, I would hope you would not need that very often in Forida! Maybe it would help when it rains really hard, LOL. Thanks! That's a great article for anyone considering one of these vehicles. Quote Link to comment Share on other sites More sharing options...
Ultraguy Posted December 10, 2007 Author Share Posted December 10, 2007 The sport suspension is a different set of sway bars and bushings (and also I think shocks); also it came with the larger wheels as standard. I've never driven the sport suspension car (they seem to be quite rare) but from the review mentioned by Jim and others I've read it was quite a good blend of ride/handling and firmer than the air suspension set on sport.The High setting seems to raise the overall ride height (as far as I can tell). The ride also gets a little harder when the setting is on High. The biggest indicator of leaking air lines or springs is when the car has sat overnight; if it looks like a low rider then you probably have a leak somewhere; also the shocks inside the air struts can leak; most dealers or service centers will see that. Someone in this forum mentioned something about using the rear sway bar from the sport suspension option as a replacement for the standard sway bar on the ultra. Welcome to the club! Recently purchased an 04 Ultra and have some questions. Is the sport setting on this car the same as the sport suspension option on the sport version....I know the ultra has air supension. Is the sport setting just a firm up the shock? Is the sport option on the regular car just a sport shock or is it springs and sway bars? Is the high setting on the suspension just for the rear when the car is laden? Or does it adjust all 4 corners? How can I check to make sure the air suspension is functioning properly and is not leaking? I am running the stock 17 inch wheels with 225/55/17 with Dunlops. Have orderd 19 inch Michelins 245/40 with 19 by 8.5 inch Modas. Wouls I be better to go with the 18 inch by 7.5 inch stock Lexus wheels? Does anybody have an opinion about this setup? Sway bar options? Thanks! OK great. Where can I get the specs on the suspension components....sway bar thickness, eg. Where can I get a sport rear bar and bushings. Thanks so much! Quote Link to comment Share on other sites More sharing options...
steve2006 Posted December 10, 2007 Share Posted December 10, 2007 Hi, You could try T M Engineering for the sway bar bushes. Here's the link http://www.tmengineering.net/ Quote Link to comment Share on other sites More sharing options...
