LexChamp Posted December 7, 2007 Share Posted December 7, 2007 I have a minor problem. I have 1995 LS and the Belt Tensioner that is bad. I can actually get away with simply changing the pulley of the tensioner which comes separately. I bought the complete Belt tensioner from an auto part but it turned out the pulley was too small. I them bought only the pulley from another auto part store and again the pulley was too small. I found a Toyota Belt tensioner pulley on EBay with the following listing: THIS IS AN ORIGINAL BELT TENSIONER FOR ALL V8 LEXUS AND TOYOTA VEHICLES. PART NUMBER: 16620-0W100. However, I called several Lexus dealer and they would not give me the part # of the Belt Tensioner and when I informed them of the part # that I had , they said it did not match the part # they had. With that said, does the belt tensioner from the Toyota listing fits the Lexus even if is not the same part #. Also, I gave the auto part store the Toyota part # and they said they can get the same part. Does anyone have the part # for the Lexus belt Tensioner? Thank you in advance. Quote Link to comment Share on other sites More sharing options...
gordonw Posted December 7, 2007 Share Posted December 7, 2007 Part number you have is for, I believe, is for 1998 LS. The 95 LS has a different part number, which is 16620-0w035. If you can get away with just changing the pulley, then you should be fine as the pulleys are the same. Quote Link to comment Share on other sites More sharing options...
VMF Posted December 7, 2007 Share Posted December 7, 2007 why not change whole thing? i changed mine and i got original oem part for like 50$ Quote Link to comment Share on other sites More sharing options...
LexChamp Posted December 7, 2007 Author Share Posted December 7, 2007 Thanks a million for that part #. I was able to order only the pulley from an auto part store for $30.00. Thanks again. Quote Link to comment Share on other sites More sharing options...
