123GS Posted December 5, 2007 Share Posted December 5, 2007 :chairshot: I'm probably stupid but i have a quick question. After removing the 5 bolt on the rear tire how to you take it off. Because I tried and the tire do not move at all. And the front ones were easy enough. Please i need your help. I have a 98 GS300 Thank! Quote Link to comment Share on other sites More sharing options...
SRK Posted December 5, 2007 Share Posted December 5, 2007 You may have corrosion locking the wheel flange to the hub. Take a large rubber hammer, or a piece of 4x4 fence post, and whack the outer sidewall of the tire inwards to tilt the flange. It should pop off quickly. Quote Link to comment Share on other sites More sharing options...
Mosh Posted December 5, 2007 Share Posted December 5, 2007 You may have corrosion locking the wheel flange to the hub. Take a large rubber hammer, or a piece of 4x4 fence post, and whack the outer sidewall of the tire inwards to tilt the flange. It should pop off quickly. Usually what I do is put one lug nut back on a few threads, and give the sidewall a good kick. Most of the time this works. If not, bust out the big hammer. Just try not to hit the rim if it isn't rubber Good luck. Quote Link to comment Share on other sites More sharing options...
djspawn00 Posted December 5, 2007 Share Posted December 5, 2007 yeah, time for the rubber mallet... just don't knock the car off of the jack! Quote Link to comment Share on other sites More sharing options...
