I am getting ready to the 40K miles maintenance on my lady friends 2004, RX330. Already read on how to extract the cabin air filter so the only thing I havn't found yet is the torque spec's for the drive shaft carrier. The maintenance schedule calls for this to be checked every 40K miles. Also, if her RX330 has the seat warmers, which I think it does, where are the on/off switches located?
Well, on my '05 330, the seat warmers are located on the center dash, and are two very small thumb switches or rheostats. Don't know about the torque specs. What does the dealer's service department say?
the driveshaft flange to rear differetial bolts (AWD) is 54 ft/lbs
Driveshaft center support bearing bolts (AWD) is 27 ft/lbs
these specs are on the RX300 but may be the same or close.
Lenore,
Is there anything you don't know....you are the ORICLE bro........thanks for all the extra knowledge....keep it coming...it is impressive to say the least....
thank you, please note these specs are out of Toyota Hylander/RX300 book. I am just guessing that the specs are about the same on the RX330....
