90k Scheduled Maintenance Es300 2002
col_forbin
Yep its in the manual, I had it done not too long ago, I believe its:
Oil change/tire rotation
Coolant flush
transmission fluid change
timing belt
spark plugs
and a myriad of other things. Its a pricey one, I paid about $1200.
My list is below (Every 90,000)
1. Timing Belt
2. Cam seals
3. Crank shaft seal
4. Power steering Belt
5. A/C Belt
6. Water pump
7. Idler pully assemblies
8. Hydrolic Tantioner
9. Spark plug
10. Wire
11. Thermostat
Hope that helps.
1. Timing Belt
2. Cam seals
3. Crank shaft seal
5. A/C Belt
6. Water pump
9. Spark plug
10. Wire
11. Thermostat
Hope that helps.
I would still like to know why you are replacing items:6, 7, 10 and 11 at every 90K on your 1997..You do not need too. Save your money.
Mechanic working in same area and requested to replace. May be you are right about Wires, Thermostat
I have mechanic who reminds me Jerry Seinfeld's mechanic so i don't ask too many questions.
This car has 288,400 miles and he is proud of it.
Thanks for tip.
@380,000 I will make sure to save money.
