Hi Guys!! :)
I hope you're OK.
Does anyone know of a list or website or whatever that describes what a person would most likely feel or hear [or whatever] if a certain, specific suspension part is becoming weak or is failing? If you wanted to know how a loose ball joint or upper control arm or sway bar bushing might effect how your car handles and/or sounds and/or 'feels' - how would you find out?
Hope this makes sense.
Thanks,
Craig!! :)
Hi Guys!! :)
I hope you're OK.
Thanks,
Craig!! :)
This might be what you are looking for...
http://www.bedlib.org/ebsco.html
Click on the big blue and green ARRC icon...
user: user
Password: password
scroll to the bottom and click the ARRC icon again..type in vehicle info.. and then click "troubleshooting" at the top... this might help you.
  • 3 weeks later...
Here is the instructions from my 90 LS repair manual.
"BALL JOINT CHECKING
1) Raise vehicle and place 8 inch (203 mm) wooden block under
one front tire. Lower vehicle until there is approximately 1/2 load on
one coil spring. Place jack stands under vehicle. Ensure wheels are in
straight forward position.
2) Move lower arm up and down. Check vertical ball joint
play movement. See BALL JOINT MOVEMENT SPECIFICATIONS table. If
movement exceeds specification, replace ball joint. See BALL JOINT R &
I.
Application In. (mm)
ES250 ......................................... Zero
LS400 .................................... .012 (.3)"
