This is my first post on here...
I have an SC400, Auto trans of course. When I accelerate the trans doesnt shift right, it jerks a couple times and then shifts into the next gear. This happens almost all the time whether i'm going slow or fast. The engine also stalls once in a while when its idling.
Anyone know what could be wrong?
Doesn't sound good.... Sounds like you have two seperate problems.... Try getting a full service tuneup and tranny service and see if that helps... Sounds like you have a dirty intake, throttle body or something.... Ecu tranny codes are a miss maybe...
The good news is your tranny isn't slipping and an engine stall out at idle is usually a simple fix....
