indiana Posted September 30, 2007 Share Posted September 30, 2007 I had the usual problem with my right rear door, the lock actuator getting weaker and weaker slowing down and eventually not working at all. I did a search on lexus actuator on ebay and came up with this part: http://www.allelectronics.com/cgi-bin/item..._ACTUATOR_.html When I opened up the panel in the door it seemed to be near impossible to install this new actuator in any way. After dinking around trying this or that. I decided I would attach the actuator rod to the manual locking cam lever on the old actuator to try and make the new actuator work. This requires leaving the old non functioning actuator and parts in place. 1. Drill a hole the same diameter as the new actuator rod in the wider part of the manual locking cam lever on the old actuator right next to the where the manual locking wire hooks up to the old actuator cam lever. 2. Cut the new actuator rod to fit your application. Bend the new actuator rod end the same way the manual locking wire is bent. Grind the rod end a little thinner as it is tight under the locking cam lever and it will rub on the housing otherwise. 3. Have the new actuator attached at the other end of the rod first. Attach the rod through the hole you made in the cam lever the same way as the manual locking wire is attached. 4. Reinstall the entire door locking mechanism back in the door leaving the actuator hanging out the access hole. 5. Attach the mounting strap to the new actuator using 2 long bolts place 2 spacers or multiple washers between the strap and the actuator this way you can put the actuator just inside the access hole in the door (spacing it carefully not to interfere with the power window) thus allowing you to screw the strap to the outer door panel. 6. You will need to cut a little of the white thin plastic protector shroud on the old actuator to make good clearance for the new actuator rod coming out through the door access hole. 7. Adjust the new actuator for locking and unlocking slack before fastening the mounting strap with screws to the door. 8. Splice the 2 new wires into the 2 larger wires coming off the old actuator (splice them in don't cut the old wires) (You may have to reverse the wires (before soldering or crimping) to make sure you have them unlocking & locking in sequence with the rest of the door locks) It actually works better than the original with shipping it costs less than 15.00 for the parts. I used lock washers on the bolts. It would probably be good to use locktight on all screws. I have no pictures, but If you read this carefully you know it can be done and is not very difficult. I haven't tried this on the front doors yet, but will eventually have to. I hope it goes as well for me... At least it wors for the back doors. Good Luck to you!... Indi Note : (This post Applies to the rear doors. I have yet to try this on the front doors. There is a connecting rod in the front door that attaches to the door key lock Which may make the front door application easier as these kits come with all the hardware for connecting rod connection. I will post on this as soon as I do a front door application) Quote Link to comment Share on other sites More sharing options...
VJZ Posted October 3, 2007 Share Posted October 3, 2007 Put this in the RX Forum? Quote Link to comment Share on other sites More sharing options...
indiana Posted October 5, 2007 Author Share Posted October 5, 2007 Put this in the RX Forum? I did. It was posted here by accident, but may be possible to do this conversion in any lexus saving buckets of coin for all.. Thanks!.. Indi Quote Link to comment Share on other sites More sharing options...
