wasabi01 Posted September 26, 2007 Share Posted September 26, 2007 My 01 is300 steering wheel shakes after i slow down when applying the brakes.does anyone know why this is happening? Quote Link to comment Share on other sites More sharing options...
smooth1 Posted September 26, 2007 Share Posted September 26, 2007 It could be several reasons: 1- slightly warped brake rotor 2- brake glaze 3- tire movement 4- uneven tire pressure 5- unbalanced tire 6- worn suspension components 7- brake pad issues 8- a combination of any of these. Quote Link to comment Share on other sites More sharing options...
izzy300 Posted September 27, 2007 Share Posted September 27, 2007 It could be several reasons:1- slightly warped brake rotor 2- brake glaze 3- tire movement 4- uneven tire pressure 5- unbalanced tire 6- worn suspension components 7- brake pad issues 8- a combination of any of these. /\ /\ /\ what he said. Hopefully your front end is okay also and you don't have a busted control arm or damaged tierods. Take it to Tire Kingdom and let them check it out... any of these repairs need attention. good luck ;) oh and he forgot BENT WHEEL :P Quote Link to comment Share on other sites More sharing options...
smooth1 Posted September 27, 2007 Share Posted September 27, 2007 It could be several reasons:1- slightly warped brake rotor 2- brake glaze 3- tire movement 4- uneven tire pressure 5- unbalanced tire 6- worn suspension components 7- brake pad issues 8- a combination of any of these. /\ /\ /\ what he said. Hopefully your front end is okay also and you don't have a busted control arm or damaged tierods. Take it to Tire Kingdom and let them check it out... any of these repairs need attention. good luck ;) oh and he forgot BENT WHEEL :P oh and he forgot BENT WHEEL The amount of the bend in the rim is referred to as movement. (# 3 on the list) All rims have a certain amount of "movement" in them. When a rim is bent or out of round, then the tire movement becomes out of spec and then needs to be replaced. :P ..... LOL!!!! Quote Link to comment Share on other sites More sharing options...
