wasabi01 Posted September 23, 2007 Posted September 23, 2007 does anybody know how to change the back lights and the turn signal lights for 01 is300? i think you have to remove the white tabs, but how do you take those out?
bartkat Posted September 23, 2007 Posted September 23, 2007 Open your trunk There are two circular clips that you need to take out so that you can access the screws. Once you get those off. Slightly lift up and it will start comming out. DO NOT PULL DOWNWARD Pull it a little up and to the left for the left housing, or right housing. It should all come off. There will be a big circle that you have to turn. and then you will get access to the light bulb.
wasabi01 Posted September 23, 2007 Author Posted September 23, 2007 Open your trunkThere are two circular clips that you need to take out so that you can access the screws. Once you get those off. Slightly lift up and it will start comming out. DO NOT PULL DOWNWARD Pull it a little up and to the left for the left housing, or right housing. It should all come off. There will be a big circle that you have to turn. and then you will get access to the light bulb. thanks bartkat, i'll try it and see what happen
wasabi01 Posted September 23, 2007 Author Posted September 23, 2007 i'm still lost bartkat, can you send pics?
bartkat Posted September 23, 2007 Posted September 23, 2007 i'm still lost bartkat, can you send pics? Try the first three steps in this DIY. That should get you to the bulbs easily. http://my.is/forums/f53/install-jdm-black-...-lights-106668/
wasabi01 Posted September 25, 2007 Author Posted September 25, 2007 thanks bartkat, that was too simple. now how do you take the front turn signal light bulbs out? is it just twist and turn or do you have to take the whole thing out?
IS3_FTW Posted October 3, 2007 Posted October 3, 2007 thanks bartkat, that was too simple. now how do you take the front turn signal light bulbs out? is it just twist and turn or do you have to take the whole thing out? Here is a post I replied too. http://us.lexusownersclub.com/forums/index...showtopic=41121
