Grinding Sound From Antenna...91 Ls400
LinuxFan
When the radio is turned on the antenna comes up. After it has stopped, the grinding begins and no physical movement is being shown on the antenna so it leads me to conclude this is happening on something internally.
Any suggestions?
This is on a 1990 LS400. Thanks in advance for your help/thoughts/input.
there is a nylon inner mast which has teeth for the ant
the motor turns to move it up or down
it sounds like the mast broke and is ust spinning its wheel on the last tooth but it can't get it to full height
do a seach for instructions on ant removal and replacement easy job to do
It is not the changing it part that disappoints me. It is the fact that I have to get a new one.
I was positioning myself to take it out and fiddle with it and bingo -- all is well. But that is not the case and so I am a bit disappointed.
thanks again :D
Here you go...
It is instructions on how to replace the antenna with a generic one, which we are not interested in, but they have to remove it to do that and they tell you how.
So it works. :D
I am looking but have not found anything as far as price goes as yet...as soon as I do I will post it. I plan to fiddle with it a bit first, so I can see how it is made up and go from there.
Wish you luck...and taking some for myself too. ;)
