sjc6765 Posted September 20, 2007 Share Posted September 20, 2007 I have a 93 sc300,, the heat is stuck on,, the only way to not have warm air blowing is to have the system off and the air on recirc. all controls seem to be working, I can select max cold,, but it is still warm. I am thinking something with the heater core,, but would like some advise from others who might have experienced this before. Thanks,, Steve. Quote Link to comment Share on other sites More sharing options...
Raine. Posted September 21, 2007 Share Posted September 21, 2007 I have a 93 sc300,, the heat is stuck on,, the only way to not have warm air blowing is to have the system off and the air on recirc. all controls seem to be working, I can select max cold,, but it is still warm. I am thinking something with the heater core,, but would like some advise from others who might have experienced this before. Thanks,,Steve. There's a small square shaped vent thingy on the dash near the keyhole area, it's hard to explain but it's positioned in front of your right knee... behind that small vent there's some sort of temperature sensor thing... when I installed my alarm I forgot to plug that thing back into it's harness and I experience the same thing you did. Try that, maybe it's causing your problem. If anyone can reply with the actual name of the parts I'm referring to, it would help LOL Quote Link to comment Share on other sites More sharing options...
soldiersoto Posted September 28, 2007 Share Posted September 28, 2007 I have a 93 sc300,, the heat is stuck on,, the only way to not have warm air blowing is to have the system off and the air on recirc. all controls seem to be working, I can select max cold,, but it is still warm. I am thinking something with the heater core,, but would like some advise from others who might have experienced this before. Thanks,,Steve. There's a small square shaped vent thingy on the dash near the keyhole area, it's hard to explain but it's positioned in front of your right knee... behind that small vent there's some sort of temperature sensor thing... when I installed my alarm I forgot to plug that thing back into it's harness and I experience the same thing you did. Try that, maybe it's causing your problem. If anyone can reply with the actual name of the parts I'm referring to, it would help LOL hey man i had the same problem with mine. i only had the car for two weeks before putting it in storage for close to 9 months so i didnt want to spend the time or money. i just pulled the fuse. i know that aint the answer u need but atleast i hope it helps u stop sweating till u figure it out. Quote Link to comment Share on other sites More sharing options...
sjc6765 Posted September 30, 2007 Author Share Posted September 30, 2007 Well,, the heat is off,,, now there is NO heat. Something must be up with the climate control unit,, or ????? Anybody else have any thoughts? Quote Link to comment Share on other sites More sharing options...
