There's only a couple of places that can repair it. But they would have to swap needles and the it wouldn't be quite the same as from the factory. I've read good and bad posts about lextech.org or you can get a new one from the dealer for $500+
No you can actually buy little tiny bulbs and they fit right behind the needles.. Replaces the neon strip...The thread is at lextreme.com...use the search function and look for "cluster lighting" or cluster needle repair"...
I used Lextechlighting.com for my needle replacement...The needles still work after one year, but the back dash lighting has blackened out already from the upgrade at Lextech lighting... I would say if you use them only do the needles nothing else...
