camlex Posted September 12, 2007 Share Posted September 12, 2007 Hello, Check engine light @ 272,000. Autozone says P0420. Needs your input. This car still runs great and I do like to keep it. Thanks Quote Link to comment Share on other sites More sharing options...
camlex Posted September 12, 2007 Author Share Posted September 12, 2007 I did reset by unplug battery, added 200 miles, so far no CEL. Thanks, Quote Link to comment Share on other sites More sharing options...
gordonw Posted September 12, 2007 Share Posted September 12, 2007 FYI, P0420 refers to the catalyst system. If it comes back on, check your front and rear oxygen sensors. Worst case would be a catalytic converter. Quote Link to comment Share on other sites More sharing options...
camlex Posted September 12, 2007 Author Share Posted September 12, 2007 I did replaced front two O2 sensors six months ago. by cat. con.still is the original. Quote Link to comment Share on other sites More sharing options...
camlex Posted October 10, 2007 Author Share Posted October 10, 2007 FYI @279,100 CEL came back needs inputs. Thanks, Quote Link to comment Share on other sites More sharing options...
dallison Posted October 11, 2007 Share Posted October 11, 2007 FYI@279,100 CEL came back needs inputs. Thanks, maf sensor? Quote Link to comment Share on other sites More sharing options...
camlex Posted October 12, 2007 Author Share Posted October 12, 2007 Thank you for your inputs. I did replaced with Universal Cat. Total cost=$185 Thanks, Quote Link to comment Share on other sites More sharing options...
camlex Posted November 5, 2007 Author Share Posted November 5, 2007 now CEL came back @284,000 with same code P0420 Needs input. FYI: After cat. con. still original O2 sensor Thanks, Quote Link to comment Share on other sites More sharing options...
anthonyiez Posted November 6, 2007 Share Posted November 6, 2007 Thank you for your inputs.I did replaced with Universal Cat. Total cost=$185 Thanks, there's your problem Quote Link to comment Share on other sites More sharing options...
camlex Posted November 6, 2007 Author Share Posted November 6, 2007 As previously posted, I got CEL and code came out P0420. So i replaced Cat. Converter @ 279,XXX.(Universal) Now i have 284,000 on my car. Again CEL shows up. run code through Autozone : P0420. While CEL on I was driving and light disappear. No more Check Engine Light. What happens? please advise. Thanks in advance.. Quote Link to comment Share on other sites More sharing options...
anthonyiez Posted November 7, 2007 Share Posted November 7, 2007 As previously posted, I got CEL and code came out P0420.So i replaced Cat. Converter @ 279,XXX.(Universal) Now i have 284,000 on my car. Again CEL shows up. run code through Autozone : P0420. While CEL on I was driving and light disappear. No more Check Engine Light. What happens? please advise. Thanks in advance.. let me try this again...UNIVERSAL CATALYTIC CONVERTERS ARE GARBAGE!!!! i do this for a living...people and other shops bring me problems cars...take it for what its worth. i wouldn't put a universal catalytic converter on anything, period! Quote Link to comment Share on other sites More sharing options...
camlex Posted November 9, 2007 Author Share Posted November 9, 2007 Thanks, replaced after cat.con. O2 sensor today. Lets see what happens next? 284,425 Miles..... Quote Link to comment Share on other sites More sharing options...
camlex Posted November 9, 2007 Author Share Posted November 9, 2007 As previously posted, I got CEL and code came out P0420.So i replaced Cat. Converter @ 279,XXX.(Universal) Now i have 284,000 on my car. Again CEL shows up. run code through Autozone : P0420. While CEL on I was driving and light disappear. No more Check Engine Light. What happens? please advise. Thanks in advance.. let me try this again...UNIVERSAL CATALYTIC CONVERTERS ARE GARBAGE!!!! i do this for a living...people and other shops bring me problems cars...take it for what its worth. i wouldn't put a universal catalytic converter on anything, period! You are right. CEL is back even i replaced O2 sensor after Cat. Which one to buy(Cat). This car has almost 285000, runs great. Thanks in advance for your help. Quote Link to comment Share on other sites More sharing options...
camlex Posted November 10, 2007 Author Share Posted November 10, 2007 I think that I found the problem. There is big vaccum line, which was losing its vaccum, so I cut about 1" from the end and installed it again. CEL light disappeared (without reset) and I hope it never shows up again. I replaced Cat. con. and O2 sensor for nothing. Lesson learned. I found this picture which somebody posted earlier, i drew an arrow, please tell me which vaccume line it is. Quote Link to comment Share on other sites More sharing options...
rembo Posted November 12, 2007 Share Posted November 12, 2007 hey there when i got my es 300 i had a chek engine light caming up and trac off light to, p0420 code the previous owner change full exausht systeme but they put a litle flow catalyzer( speling in english??), like the one for the corralla or camry 4cinlinder and it was to much restriction i put a Hi Flow catalyt systeme and no more trouble rem Quote Link to comment Share on other sites More sharing options...
powerbob Posted November 27, 2007 Share Posted November 27, 2007 hey therewhen i got my es 300 i had a chek engine light caming up and trac off light to, p0420 code the previous owner change full exausht systeme but they put a litle flow catalyzer( speling in english??), like the one for the corralla or camry 4cinlinder and it was to much restriction i put a Hi Flow catalyt systeme and no more trouble rem Did the Hi Flow cat converter correct the check engine and trac off light problem? Did you notice if the car would not shift into Overdrive consistently? I have noticed that the transmission will not shift from 4 to 5 consistently with the check engine light and trac light on. My mechanic was seeing a code 61 but could not decipher the code 61 meaning. bob Quote Link to comment Share on other sites More sharing options...
camlex Posted November 27, 2007 Author Share Posted November 27, 2007 After i replaced rear O2 sensor(after cat. con.), everything back to normal. with 287,300 runs like NEW. Quote Link to comment Share on other sites More sharing options...
