bicol-ini Posted August 23, 2007 Share Posted August 23, 2007 hello, got the dreaded cel, pulled out the code its a P0306, misfire cylinder 6, where to start? plugs, wires, coils, happened to anybody? any info greatly appreciated, 96LS400 with 172000 mi, thanks Quote Link to comment Share on other sites More sharing options...
blake918 Posted August 24, 2007 Share Posted August 24, 2007 Gill, I'd start with the plugs and wires just like you mentioned. ;) I had the same codes because I had filled the spark plug tubes up with water while cleaning the engine. LOL :chairshot: New plugs and wires did the trick for me. Quote Link to comment Share on other sites More sharing options...
bicol-ini Posted August 26, 2007 Author Share Posted August 26, 2007 hello, there blake, how are you its been a long timeanyways, like i said in the post, so i started with the plugs with the suspected 6th cylinder, yep, its the plugs, so removed all the plugs, inspected the plug holes, top pistons normal carbon, check on the wires resistance, theyre all with in specs, am putting in new NGK plugs, Quote Link to comment Share on other sites More sharing options...
