djjesq Posted August 22, 2007 Share Posted August 22, 2007 Does anyone know how to turn off the TRAC on the 07 ES350. The car is lousy in the snow with it on. Can't get up my driveway in an inch of snow Quote Link to comment Share on other sites More sharing options...
ZeeD Posted August 22, 2007 Share Posted August 22, 2007 I dont think you can turn the traction off.... You are better off checking with your dealership how it will be possible to drive over snow. Quote Link to comment Share on other sites More sharing options...
amf1932 Posted August 23, 2007 Share Posted August 23, 2007 Although I never used it, there's supposed to be a switch on the bottom of the dashboard to the left of the steering column that disengages the TRAC. It will stay off until you stop the engine and than it'll automatically re-engage when restarted. Don't mix up this switch with the tire pressure monitoring switch which is next to it. Quote Link to comment Share on other sites More sharing options...
wwest Posted August 23, 2007 Share Posted August 23, 2007 Although I never used it, there's supposed to be a switch on the bottom of the dashboard to the left of the steering column that disengages the TRAC. It will stay off until you stop the engine and than it'll automatically re-engage when restarted. Don't mix up this switch with the tire pressure monitoring switch which is next to it. While the engine is running unplug the MAF/IAT module sensor, the engien will die, plug the sensor back in, restart the engine. For the next few drive cycles you will have a CEL and ABS/TC/VSC/etc, off indication. Quote Link to comment Share on other sites More sharing options...
