nester Posted August 21, 2007 Share Posted August 21, 2007 I am going to replace 2 front Oxygen sensors on my GS430'01. Which part number should I look for? There are a lot of different numbers even among Denso - e.g. front left: C5010-112388; W0133-1604947; 2344138 for $110-$150. Which one would be more "OEM-like" and also which site is the most trusted and reliable to get original parts? Quote Link to comment Share on other sites More sharing options...
CarbonGS Posted August 21, 2007 Share Posted August 21, 2007 i was needing the same. i went with an o2 simulator instead. it is cheaper and you can get headers if you want afterwards. http://webstore.o2simulator.com/index.asp?...OD&ProdID=5 it is only $30 and make sure you get the dual output simulator. now you can also get headers if you'd like without a CEL. Quote Link to comment Share on other sites More sharing options...
nester Posted August 22, 2007 Author Share Posted August 22, 2007 i was needing the same. i went with an o2 simulator instead. it is cheaper and you can get headers if you want afterwards. Thanks anyway but it's not for V8, not the front and I need real sensors, not the 'plug'.. Anyone knows about part numbers? Quote Link to comment Share on other sites More sharing options...
djspawn00 Posted August 22, 2007 Share Posted August 22, 2007 i was needing the same. i went with an o2 simulator instead. it is cheaper and you can get headers if you want afterwards. Thanks anyway but it's not for V8, not the front and I need real sensors, not the 'plug'.. Anyone knows about part numbers? Not a v8? a 430 is a V8. You can call up your local lexus dealer and get the part numbers then instead of getting it from them contact oxygensensors.com or rockauto.com with the OEM part numbers and they'll get you the right parts. I've used both but without getting the OEM part numbers, both sites tell what sensors are OEM type and what banks they go to. Quote Link to comment Share on other sites More sharing options...
