mongray Posted August 20, 2007 Share Posted August 20, 2007 Help please. I have a '99 gs400. I brought my car in for an alignment at some shop and there is a pen ink stain right next to the ignition (same material as the dash). i haven't tried anything yet, since i fear i may make it worse. Is there any product or anything I can do to remove the stain. I've heard of trying wd40, but I'm a little weary. Any suggestions? thanks. Quote Link to comment Share on other sites More sharing options...
LEXIRX330 Posted August 21, 2007 Share Posted August 21, 2007 Help please. I have a '99 gs400. I brought my car in for an alignment at some shop and there is a pen ink stain right next to the ignition (same material as the dash). i haven't tried anything yet, since i fear i may make it worse. Is there any product or anything I can do to remove the stain. I've heard of trying wd40, but I'm a little weary. Any suggestions?thanks. Try to use some soap and water. If that won't take it off try some leather cleaner...I would be cautious of using anything like goo gone or goof off on it...but if nothing else works then give that a shot but use a small amount. How bad is the ink stain? I would think that the ink should come off with a mild soap... Good Luck! Quote Link to comment Share on other sites More sharing options...
LexKid630 Posted August 21, 2007 Share Posted August 21, 2007 GooGone will be fine for that. You need to scrub to get the pen out though; it may take a while. Quote Link to comment Share on other sites More sharing options...
mongray Posted August 25, 2007 Author Share Posted August 25, 2007 thanks guys for your suggestions. i'll try the soap/water first, and if it doesn't work then goo gone. thanks again. Quote Link to comment Share on other sites More sharing options...
