I was making a U turn when my ac went out. The back lights work. No heat, fan defrost, and my outside air temp gauge doesn't work. Everything else does. I checked all fuses. They are good. I pulled out center dash above radio and connection are tight. What would make both of these go out at the same time? HELP HELP HELP :cries:
Hi,
I cannot find anything specific but there are at least 4 fuses involved in the ac have you checked them all?
Cheers,
Steve
Hi,
Cheers,
Steve
Thank you for spending the time on my problem. YES you are right it was a fuse that looked ok but was not making contact correctly. Once again thankyou for your help. :cheers:
