Abs And Traction Control System
rembo
hi there
all start a few weeks ago when i slip on the water (aquaplaning) splelling????
well the traction control light appear in the dash and stayed light
so i was told that the abs and tration control management was the same
and obviously its not working right
so here is the question
does a management from a toyota camry v6 abs ( assuming that traction control to)
if not how much one from lexus approximatly is???
why would you let someone replace the system when you don't know what is wrong with it? you like giving money away?
Read the ABS code, it will tell you the problem. Fix the problem. Typically it's just something cheap like a wheel speed sensor needing replacing, or has been knocked out of alignment.
  • 7 months later...
I've been quoted 350 by toyota to fix my speed sensor. If i buy the part for 190, can I install it myself?!?
Thanks in advance
Thanks in advance
I would suggest removing/cleaning/re-adjusting the speed sensor gap first. Metal filings, "fines" covering the sensor tip can be a problem as would poor electrical connections.
The sensor itself rarely fails.
hello, i tried to clean it, but couldnt even remove it! What tool is best to remove it? any tips!
Thanks in advance
Thanks in advance
any tips to remove this wheel sensor
  • 6 months later...
How do you read the ABS code? I've tried to search the forum but I can't use 3 letters in my search without getting an error. Thanks in advance.
