fooldall Posted July 24, 2007 Posted July 24, 2007 Good morning, everyone! I was wondering if anyone knew some troubleshooting steps for this error code- I did some searching and found info on the vacuum servo on the firewall behind the ABS system- but I'm not sure that this is where I need to begin looking.. Anyone have any more specific info on this error? Where do I begin?
GrnHrnt Posted July 24, 2007 Posted July 24, 2007 Factory manual for 2000 model year says code 41 indicates a problem in the air mix servomotor "circuit". Trouble could really be : 1)Air mix servomotor, 2)Air mix damper position sensor, 3)Harness and connector between A/C control assembly and air mix position sensor, or 4)Harness and connectorbetween A/C control assembly and air mix damper control servomotor.
fooldall Posted July 25, 2007 Author Posted July 25, 2007 Is the air mix servomotor the vacuum controlled servo right behind the ABS system? Where do you recommend i start troubleshooting? Also, pics would be helpful, as I have no real service manual.. Thanks!!
GrnHrnt Posted July 25, 2007 Posted July 25, 2007 Air mix servo motor is inside vehicle under the dash. A good, fast way to troubleshoot is with help of a factory service manual. You can download all you need for $10.00 a day at https://techinfo.toyota.com/
