How Do I Replace My Cornering Light Bulbs?
My left cornering light is not working. What is the best way to get at the buld to change it?
Thanks.
Bulb socket is located all the way at the end near the fender. Just reach in there and unplug the connector and twist the socket and out pops the bulb. Just replace and follow reverse order!
Thanks.
Thanks Kramer,
Do I remove belly pan or wheel well liner for access?
DaveMcKenz, Just remove a few bolts on the fender splash guard, use a flaslilght to locate the corner light casing. Turn it counter clockwise to gain access to the bulb.
Done.
The bottom, front part of the wheelwell liner wraps forward and attaches to spoiler lip and belly pan. Remove this by pulling about 8 screws. (First turn the wheels to full lock toward side you are working on. No need to jack car or remove wheel.) Reach inside and turn socket counterclockwise to release. Then insert new #1156 bulb. Assembly is reverse, but it's a little hard to get it all lined up.
Thanks for the help.
Dave
